Aspire 5750: Power cord not charging, consistently. Tried 2 generic cords at BB and nothing..Help?
charno
charno Member Posts: 2 New User
Can sometimes hold in 1 spot and get charge, but getting worse. Does Acer allow generic power cords? Got absolutely nothing from 2 that the Geek Squad tried. Battery low so charging via AC critically important I resolve..
  • laurent_14
    laurent_14 ACE Posts: 10,397 Trailblazer
    Hello,
    It depends on the quality of the AC adaptor (price).
    You'll find below the part numbers of the original AC adaptors:
    AP.06501.026AC ADAPTOR.65W.19V.YELLOW
    AP.06501.033AC ADAPTOR.65W.19V.YELLOW
    AP.06503.024AC ADAPTOR.65W.19V.3P.YEL.LF
    AP.06503.029AC ADAPTOR.65W.19V.3P.YEL.LF
    AP.0650A.017AC ADAPTOR.65W.19V.YELLOW
    AP.09001.031AC ADAPTOR.90W.3P.BLUE.LF
    AP.09003.021AC ADAPTOR.90W.3P.BLUE.LF
    AP.0900A.005AC ADAPTOR.90W.3P.BLUE.LF
    France
  • charno
    Actually, Acer Store says AK.065AP.013; 65W.
    1) Where did your #s come from? And
    2) Does Acer require OEM only?
  • laurent_14
    Yes, Acer changes suppliers so they change the P/N (Product Lifecycle Management).
    1) From Acer.
    2) I've already replied to your question.
    France
  • Hi, When you say works when you hold in 1 spot, is that the adaptor is loose & you need to hold it in a specific point to charge, if Yes, then the problem is with the Adapter connector in the unit, better to check for any damages or wear n tear,.
