I HAVE PROBLEM WITH TUCH PAD IT IS NOT WORK ANY HELP PLEAS
HEBAALE
HEBAALE Member Posts: 3 New User
TUCH PAD DOES NOT WORKING I NEED HELP PLEAS
  • Phil-3
    Phil-3 Member Posts: 1,179 Seasoned Practitioner WiFi Icon
    Hello HEBAALE and welcome!
    Please provide the model number and description of your device so we can move this question to the proper location.
    Thanks.
  • HEBAALE
    Man HappyMan HappyThank you very much for your interest and I will send you the required I hope to find a solution to the problem I've  instal  definition of your page is a special my computer but it did not work and when it was admitted to the settings of the mouse can not find widget name or definition and Settings its own program
  • HEBAALE
    The name of the operating system Microsoft Windows 10 Pro
    Version 10.0.14393 construction 14393
    Another description of the operating system is not available
    The manufacturer of the operating system Microsoft Corporation
    System name DESKTOP-9PAB4TS
    The manufacturer of the system Acer
    System model Aspire ES1-512
    System Type x64-based PC
    SKU system EA53_BM_083D_1.15
    Processor Intel (R) Celeron (R) CPU N2840 @ 2.16GHz, 2159 MHz 0.2 basis (fundamentals) 0.2 processor (processors) logical)
    Version / Insyde Corp. BIOS Date V1.15, 20/07/2015
    Copy SMBIOS 2.7
    Console version included 1.12
    Old BIOS setting
    BaseBoard Manufacturer Acer
    BaseBoard Model Unavailable
    BaseBoard Name Base Board
    The role of the Statute of the mobile
    Safe Boot is a certified case
    Formation PCR7 connectivity is not possible
    Windows C: \ WINDOWS directory
    The system directory C: \ WINDOWS \ system32
    Operating device \ Device \ HarddiskVolume3
    Locale Jordan
    Abstract class hardware version = "10.0.14393.0"
    DESKTOP user-name 9PAB4TS \ redwa
    Jordan's time zone - Daylight Saving Time
    Installed physical memory (RAM) 2.00 GB
    Total Physical Memory 1.89 GB
    Available physical memory 364 MB
    Total Virtual Memory 3.30 GB
    Virtual memory available 1.06 GB
    Paging file size 1.41 GB
    Page C: \ pagefile.sys file
    Hyper-V - VM put surveillance Yes Extensions
    Hyper-V - Extensions second level address translation Yes
    Hyper-V - has been enabled in the virtual firmware Yes
    Hyper-V - Data Execution Protection Yes
