Acer cb5-311 battery light won't stop flashing no battery indicator
Tom82
Member Posts: 1 New User
So the computer is maybe 3 years old. It sat for 6 months then would only run with the power adapter plugged in. Battery light alwasy flashing orange. I replaced the battery now it works totally fine. Runs off ac power no issues with battery life but the orange battery light will not stop blinking and there is no battery life icon. Crosh battery test shows no battery found. Which is exactly what it did before I replaced the battery when it wouldn't run unless plugged in. Does anyone know what this problem is. Acer refused to help since it's not under warranty. Thanks
0
