2012 Archives
This page has been archived.
The content on this page may be out-of-date or have been superseded by newer information, and links on this page to other sites may not work. This page has been archived for future reference.
See our Discussion Forums for more current content.
Tema
Responder
Regular Visitor
acer_user_me
Envios: 2
LCD monitor - H233H , Monitor will flicker for seconds, dim, and then go blank.
Monitor turned off during normal use this week.  Turning the monitor back on shows the screen for about a 2 seconds, a series of quick dimming flickers,  a hiss/pop from the panel (not the board), and the screen goes blank. Computer is good as I am using a backup monitor now.  Took monitor apart and I am not seeing any obvious dead capacitors or other burned board components.  Definitely can smell ozone with the cover off and trying to cycle the power.  I have not taken the LCD panel apart yet since I was hoping it was a capacitor.   Looking for advice on what to check next.
Acer Technician
Acer-Tommy
Envios: 6.351
Re: LCD monitor - H233H , Monitor will flicker for seconds, dim, and then go blank.
We are unable to advise anyone on board or component level repair.
We would suggest contacting technical support in your region for further assistance with this issue.
Acer Service and Support
Important Links: Global Support Pages | Knowledge Base Articles
Remember to mark posts that resolved your issue with Accept as Solution. You can even mark multiple posts in a single thread. This will make it easier for others to find the same information. Use the kudos-thumbs-up.png Give Kudos button to offer a thumbs-up for good post content and a pat on the back to the author.
Regular Visitor
acer_user_me
Envios: 2
I went to your support page and it confirms  my product is out of warrenty.  That page suggested I try the forums.  Now you have pointed me back to where I came from.
Lets start here
https://customercare.acer.com/customercare/CaseBooking.aspx
First, I find I can't right click and paste the SNID number.  Okay, I will type that in.
Second, try to click date, nothing happens.  Try next.  Nope
Third, now I will type in the 11 digit code, again, and the 23 digit serial number. Then try next or date.
Result - nothing.
So I guess I will go back here.
http://support.acer.com/us/en/default.aspx
Lets try Support.  A window wanting my SNID number appears.  This window looks familar, oh yes, I tried that on Saturday.  I guess the good thing is after not being able to right click and paste the SNID, I have the number memorized by now.  So lets try entering it again.
Answer, its out of warrenty, please try one of the other options.  Okay, what other choices do I have.
I found my solution here.
http://support.acer.com/us/en/answers.aspx
The solutions look a pricey, but lets see what they say.
For $20, I can find out how to set my home page - wow
$30 - set up email - great deal
$80 - see sales agent, huh
Nothing about an LCD monitor. To pay someone to say, your 3yr 5mth LCD, its dead Jim and will cost $120 to repair is preposterous. However, I will take free forum advice that it is irretrievably dead and save my money for a new LCD.
Bem Vindos
Não é um membro?   Registrar
Ajuda
Idioma:
Usuário Destacado
Convidamos todos os usuários da Comunidade a dar Kudos para nosso amigo Lucas2014. Contamos com sua colaboração. Sua participação tem sido de grande ajuda aos nossos outros usuários da Comunidade Lucas2014.
Contributor
Você sabia?
Acer Community também está disponível nos seguintes idiomas:
