Revo Build Noise and temperature problems.
Monberg
Monberg Member Posts: 6 New User
Hi All..
I just bought the Revo Build, and are sensing some issues.
The fan is fairly noisy, and starts all the time.
The temperature, even in Windows Idle, is about 50 Degrees, hvich i think is pretty much. Taken into consideration that the CPU is barely working.
The fan speeds up and down all the time.
Is there a way to make this better? I love the concept, but it might be a bit bad designed as far as cooling goes.
Hope you can help.
  • jemward
    jemward Member Posts: 1 New User
    I have the same issue. The cooling fan speeds up and down all the time, goes off for a few seconds and spins up again even when PC is doing nothing. Did you manage to get yours fixed?
  • Monberg
    Unfortunately not.
    Im guessing ill tear it apart once the unit is out of guarantee, and then maybe make a better cooling solution. Untill then i keep it in a closet with the doors closed when not using it.
    Regards:
    Monberg75
