Let's Get Social!
Ask our members for help or assist others.
You are all welcome at Acer Community!
cancel
Showing results for
Search instead for
Did you mean:
This page has been archived.
The content on this page may be out-of-date or have been superseded by newer information, and links on this page to other sites may not work. This page has been archived for future reference.
Visit our Product Forums for more current content.
Acer Iconia A1-810 (android 4.2.2) - problem charging battery after setting up
New User
Since buying it from Argos, i have only been using it for a day and there is no way i can get the battery to charge up.  It seemed to have charged up the first time you do it before turning on the tablet to do your settings etc.  Since then, i have not been able to charge it, so used the device from main power.  I gathered that you have to fully shut down the tablet (power down) to charge properly but when i go to my tablet and check the battery status from SETTINGS app (unplug the power cable), it show seconds left on battery and even then, this number changes.   Also when the message on the SETTINGS against BATTERY say charging A/C, it shows at 94%?  Where does the problem lie?
Another thing, things did not go smoothy with my intial setting up because i made the stupid mistake of leaving the device alone BEFORE completing the Google account linking and Acer registering etc but had entered the internet password but when i went back, i panicked when i saw the lock sign...still i managed to get in and tried connecting to Net with authentication problem, eventually i gathered i had lost my internet password when i left the device which i managed to reinter.  Then later i figured how to push the lock sign away so i wasn't fully locked.  Would i be better of restarting the tablet just because first time i messed it up and may have had upsetted the battery charging function.  Is this possible or there is a known problem with Acer iconia A1 for battery charging on Android 4.2.2
New User
Re: Acer Iconia A1-810 (android 4.2.2) - problem charging battery after setting up
Ok i think i may have been seriously misled by the info that you see on the SETTINGS against BATTERY, for someone who has never owned a smartphone or tablet, it can be easily misinterpreted.  When i see '30s on Battery', i thought it was saying you only have 30 secs worth of battery usage!!!  I did not check the tiny battery icon on the SETTINGS screen but the single battery meter you get on quick 1 click switch of the tablet is confusing.
Seasoned Specialist
Recommend you download GSam battery monitor from Google play, accurate and free.
